Old 04-14-2014, 01:24 PM
kevins2's Avatar
kevins2 kevins2 is offline
Cobra Make, Engine: ERA #795 427 S/C completed Jan. '14 - '68 FE 427 side oiler
Hi Dan,
I initially had the same problem with my right turn signal. It worked but then when I put the steering wheel on it stopped working. I then tried having the steering wheel on loosely and the right turn signal worked fine until I tightened the steering wheel - then it wouldn't work. I finally figured out that by having a small space between the steering wheel and the column assembly the problem went away. I spoke with Bob about this and, although I'm not sure the problem made sense to him, he suggested loosening the lower steering column bracket and pulling the shaft out just a bit. That's what I did - literally just 1/32". That solved the problem.
As strange as this may sound, it would be easy enough to remove the steering wheel and see if your signal works.
Kevin
"Anyone who drives faster than you is a maniac and anyone who drives slower than you is an idiot" - George Carlin
