Old 04-14-2014, 05:49 PM
1985 CCX's Avatar
1985 CCX 1985 CCX is offline
Its been awhile and the weather is allowing forward progress.............
Electrical:
Firewall complete
Trunk all wired however not fully trimmed
Engine all set
Front lights and fans under way
Dash last..........
So wanted to post my top......
1964 original top, from a friend
There will be some adjustments needed as the roll bar hangs it up and the center front naugha is split about 2" in the center between original window sill bracket. Easy repair and adjustment by vinyl guy. The rubber hose in the felt window opening needs to be replaced as the old stuff is brittle. Very pleased, this car may see three seasons when under its own power...
Cool part is the hardware and the patina on the lift-o-dots.
Rear glass can be seen through and the placement of the pins on my car accepted the top WOW
Needless to say very cool item.
