Thread: Fuel dumping?
Old 04-05-2002, 09:17 PM
RaceDeck's Avatar
RaceDeck RaceDeck is offline
Cobra Make, Engine: "ORIGINAL" Kirkham #302-Stainless Steel Chassis w/Billet suspension -427 Shelby Aluminum block stroker 495ci by Kinetics Race Engines
Default Fuel dumping?
I am having some trouble with my Holley 750.....Under hard accelleration, it starts to cut out and there is a heavy smell of fuel. we replaced the floats and seats and still a problem. I am only running a mechanical pump and it is at around 9psi. When I take the side screws out ot see where the fuel is at , it is right at screw level when at idle. The motor runs at around 170 to 200 degrees max and the carb is not very hot to the touch ( just warm) ....??? we had a problem earlier with the the floats....the floats were not operating and fuel was comming out the vent tubes....
Any thoughts. I do have a turkey pan on it if that changes anything????
THanks
RaceDeck
