Thread: Engine ID
Old 04-20-2014, 08:56 PM
Wbulk's Avatar
Wbulk Wbulk is offline
Cobra Make, Engine: 66 Cobra
If the 352 is cast in the front of the block it could be a 352, 360, or 390 or several others. They all used the 352 cast block. The stroke was different on the 390.
Added:
Then there were also the 330 and other FT truck engines that used the 352 casting block. The C6ME could be a 330,359,361,389, or 391 FT truck engine I believe. The date code would be 11-19-65. 5=65, K=11 month, 19= the day. Who knows what you have. But it does look like you have a FT truck engine.
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
