Old 04-21-2014, 04:12 AM
mnm99's Avatar
mnm99 mnm99 is offline
I'm in the same boat. Here is a guy on 460forums that builds only BBF. A 460 with I know it's not top of the line stuff, but a pretty good price. He breaks in the motor and checks for leaks before it's shipped. He uses Procomp heads that he goes through before installing. But then again, I'm looking at buying a NEW Backdraft and this will be a tight fit. Still got to do some research on how hard it is to say change the plugs ext....
Street Hustler Crate Engine: $4995.00
-472 Cubic Inches
-Weiand Stealth intake manifold
-Reconditioned factory CJ connecting rods
-Reconditioned factory crankshaft
-Probe forged pistons
-Speedmaster aluminum heads
-Pent roof aluminum valve covers
-Lunati aluminum Roller Rockers
-Lunati hydraulic flat tappet cam and lifters
-Lunati custom length pushrods
-High Flow Dynamics oil pump
-Choice of front or rear sump oil pan
-545 HP at 5500 rpm, 585 lb/ft at 4000 rpm
-Premium unleaded pump gas compatible
-Test fired, broken in, with 90 day unlimited mileage warranty
-Truck freight $350.00 in the lower 48 states
-Will be delivered as pictured below-email or call for pricing on custom options
Specials
