Old 04-23-2014, 03:08 PM
kevins2's Avatar
kevins2 kevins2 is offline
Cobra Make, Engine: ERA #795 427 S/C completed Jan. '14 - '68 FE 427 side oiler
Jim,
If I recall correctly from Dan's original thread on this problem, everything was working properly and then stopped working without any changes being made. If I recall that correctly, it isn't a crossed wire. But since you mentioned pin connectors, when I put my wiring together a few things didn't work initially and I discovered 3 pins that weren't "clicked" into the pin connectors. So, when I connected them, those wires just pushed out and didn't make connection. It was easy to correct - just click the pins into place. So Dan, a long shot, but it is possible that you have a wire that was making a connection but then the pin backed out a bit more from vibration. You've probably already checked all the connections at this point...
"Anyone who drives faster than you is a maniac and anyone who drives slower than you is an idiot" - George Carlin
