Old 04-24-2014, 07:18 PM
Large Arbor Large Arbor is offline
Cobra Make, Engine: ERA 714
Ok, so I pulled the seats, rear panel, carpet, transmission cover, and am already to pull the transmission on Saturday. I took measurements from the bellhousing / block shield to the ring gear and it is exactly 3/4". That is just to the front block side of the ring gear. The CVR starter is only connecting with the ring gear by less than 1/4". So, I will need to find a starter that has axial movement of 3/4" from the shield. That should solve the problem. It was not too bad to remove what I have so far and will try to post pics tomorrow. The new ring gear came in the mail and I hope to have that pressed on Saturday as well. Thanks for all the wisdom shared. More to come...
