Old 04-25-2014, 04:32 AM
indianamoon's Avatar
indianamoon indianamoon is offline
Cobra Make, Engine: B & B 289
As I look thru the car carefully, I see a number of improvements that I will make before finally putting it on the road. Lots of really good components used in the build, but then things like this done? Some workmanship is truly top notch, but then I find something like the bolts for the pedal assy's put in backwards, so they can't be taken out without dropping the entire pedal box. Lots of little adjustments needed to what really appears to be quite a nice car.
Three peaks, you are right, the wiring needs some major attention. Seller told me that everything works on the car. What he meant was that the car runs. Whenever anything on the dash is turned on, the voltage goes to about 6 volts or so. Wipers are slooooooow motion. Gotta do some major digging on that one. Just got the schematic, so will start trouble shooting s soon as I replace that battery and re-work the hold-down strap. Still can't believe that anybody could do that, or that it survived the cross country trip in the transporter. Hey, that woulda been an impressive fire, taking out a half million in collectors cars and the rig????
