Old 04-25-2014, 08:50 PM
DanEC's Avatar
DanEC DanEC is offline
Your slave cylinder should bolt to the block if it's the external type. You just need to pull the rod. If you have a hydraulic throw out bearing I'm not sure - it may come out through the clutch fork hole once the transmission is pulled without breaking the line.
