I snipped off the connector's plastic casing coming from the column because I could not find a matching connector. Once the plastic casing was revealed, I simply had a bunch of wires with connectors. At the local Auto parts store I found electrical connectors that fit the wires from the column. I then conected each wire individually. A little shring tubing some tape and it seems to work fine.
Just enough knowledge to build a cobra and be dangerous...
You can observe a lot from just watching.
