  #72 (permalink)
Old 04-29-2014, 06:45 AM
Hail427's Avatar
Hail427 Hail427 is offline
Cobra Make, Engine: Pace 427CC 3UZ FE V8
Originally Posted by pigsear View Post
Hail,
If you asking for a durable and inexpensive carpet that will get wet then try a marine store such as bias boating. I would be surprised if a factory cobra had carpet. Also a car upholstery person may need to be consulted as trimming and finishing carpet edges neatly is a skill.
Regards, Pigsear.
Hi pigsear, you are right the carpet will need trimming and I don't know
If anyone has tried but also put Velcro on the carpet and the body areas around footwells Back cabin/boot wall and center hump, just so the carpet can be removed for cleaning and it would be easy to remove and replace worn or damaged carpet that's why I didn't want it to be to pricy but put in the right locations it would cover most areas, I can see the only problem would be due to heat? Any thoughts or comments.
parts pile until the first start then it is a car
