Old 04-30-2014, 09:07 AM
saltshaker saltshaker is offline
Cobra Make, Engine: Contemporary Cobra
Rick, when syncing carbs cylinders 4&5 are off from the other 6(FE Motor) with regards to shutting down a cylinder with the mixture screw there is a cylinder that doesn't shut down. Would you blow air in the passage to clear it? Comp cam 282s 110cl 236@.50 577lift
Jon
