Thread: Switches
Old 05-01-2014, 04:46 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
If you are referring to the manual radiator fan switch on the dash, it is only a ground. no power load from the fans.
Unless someone did a self install without knowing how it works that is. When you say the switch "locked up" do you mean "FUSED" itself so it won't operate or just fell apart?
Consult your wiring diagram.
SPFWiringDiagrams@Comcast.net
