Old 05-04-2014, 11:31 AM
blykins blykins is offline
Here's a heavy old FE piston....
And here's a light Windsor piston....
Neither one of those are what I would consider "exotic". They are both custom pistons from Diamond, and the FE piston is for a 4.125" stroke, which makes it taller than the pistons I would use for a 4.250" stroke build.
You will notice that the Windsor piston has a pretty substantial 30cc dish in it, while the FE piston has a small 14cc volume. You can also note that the Windsor piston uses a support rail, which adds to the piston/ring package weight.
The FE piston could have been made extensively lighter.
Just one piece of the puzzle of course, and rod design/weight makes a pretty substantial difference in itself, but it's easy to see that you can cut down big block reciprocating part weight without a lot of effort.
I would also suggest that the non-builders here look into the difference between "rotating weight" and "reciprocating weight", which we use to both balance and to pick lightweight combos for race applications.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
