Thread: Advice
Old 05-07-2014, 01:22 AM
RallySnake's Avatar
RallySnake RallySnake is offline
The Battery Tender will not do a good job of charging your battery from dead. You need a more powerful charger for that.
I have had similar things happen to me. Once it was the choke that was stuck closed. On four occasions, the electric fuel pump failed. (Now I run two.) Another time, it was the relay in the engine compartment that provided power to the ignition. The contacts had corroded in the relay socket. Another time it was the MSD 6A ignition box. (I ran two of those for years before switching to the Ford EDIS system with a Megajolt). Another time the bearings failed in the camshaft's gear drive. (I switched back to a chain drive.)
The worst time took more work. When I took the air filter off the carburetor and turned on the electric fuel pump (without starting the engine), gas flowed out the Holley's rear vent tube. After doing lots of work on the carb, I found out the the pressure regulator in the Carter fuel pump had failed and was putting out 12 pounds of pressure instead of 5. The carb's needle and seat cannot handle pressure that high. Now, I have a Holley pressure regulator and a fuel pressure gauge in the fuel line before the carb.
Good luck,
RS
