Old 05-07-2014, 11:24 AM
DanEC's Avatar
DanEC DanEC is offline
Patrick - I have the Jag rear suspension and I can bleed the brakes from underneath with the speed bleeders, but to bleed it the old fashion way or install the regular bleeders I will have to pull the seats and rear panel out. Trying to avoid that unless I have no choice. Basically - I'm going to fill the MC with fluid standing on end - from the end port and lightly pump the rod - then install the brake light switch in the port. So in effect it will be bench bleed. Of course I still have to get it in the car and hooked up to the two lines. It's the one inside next to the rail and it's a lot more difficult to get into position and bolted up versus the outer one.
