Old 05-10-2014, 04:43 PM
Scotchman's Avatar
Scotchman Scotchman is offline
Cobra Make, Engine: FFR MK3/302/570 street avenger
HarleyD,
The new sender works just fine, like all the others at first. It's the same exact part, 4th one in 6 years. Speed Hut Oil 0-100 psi pressure sender-part # G-SNDR-09. You can see a pic on their web sight under Other Products/Gauge Accessories/Senders-2nd page. There may be problem with my set up, causing the part to go bad. Sometimes you just have to be a detective to figure this s#%@ out!
