Thread: U Joints issue
Old 05-11-2014, 06:23 PM
LMH's Avatar
LMH LMH is offline
Just a reminder (you probably already know this but...), when you install U-joints, make sure you install the Zerk fittings so that they are under compression when torque is applied to the driveshaft. I've seen them installed wrong and the U-joint broken at the hole for the Zerk fitting.
Alba gu brąth
