Old 05-11-2014, 07:12 PM
hercf16's Avatar
hercf16 hercf16 is offline
Originally Posted by mattpatt View Post
For what it's worth I put a KC SBF 427 with a Dart aluminum block in my cobra. Reasons: 1) Roush is BIG - the good is a very good "we'll fix your problem" record and dealers are close by (everywhere?). The concern is that they have many "certified" builders vs. KC who does it all in his shop - I assumed this meant more control by Keith over the quality/who's building it, etc.part. 2) Price: got essentially the same quality parts plus upgraded to the DART aluminum block and it still cost less (including shipping). While the downside of a KC engine is that you have to deal with Arkansas instead of a local dealer I have to say that I had a shipping problem that damaged the oil pan and carb and with no questions asked KC immediately shipped replacement parts at KC's cost. The engine has run flawlessly so far (only 3000 miles and not racing) but it is definitely strong. I ordered a slightly de-tuned version of the KC 580HP motor. KC measured it at 554 HP at 6000. After installation I put it on a chassis dyno (inertial dyno in 4th gear - 140mph max) and got ~425HP so the KC dyno number seems to be reasonably good. By the way, torgue was something just north of 580. Given that this motor is lighter than the original 289 and ~12% more powerful than the original FEs I'm guessing Carol would have given his eye teeth for this motor in '65. Not only does the 554 HP keep the power to weight ratio ~the same as the original (slightly heavier SPF still behaves like an original) you can drive it to breakfast or in heavy traffic with no problem. By the way, I get 16 mpg (freeway) with a carb. <{:>))
Looking at a few with Roush, kind of like the 427R, and one with a KC 482
with Pond Al block. I have always heard good things about KC until last week
when I learned of a low mile, 350ish, that had to be shipped back with a
vibration and oil using problem. But I'm sure that happens to them all every
now and then, hell the 997.1 Turbos have a few issues.
Going to check out the KC Cobra next week in Vegas, was at Hillbank last
week, nice tour and test drive, they go through all the used cars they get
in before they turn them.
Herc
Herc
