Old 05-11-2014, 08:36 PM
Scotchman's Avatar
Scotchman Scotchman is offline
Cobra Make, Engine: FFR MK3/302/570 street avenger
Dan,
The unit was supplied by Speed Hut to Factory Five and was included in their complete kit package. It is supposed to be compatible with their gauge. I did install an arm that comes out of the block with a terminal wire at the end of the arm which goes to the red light indicator on the dash for low oil pressure, and the Oil Pressure Sending unit is inserted into that arm. It is a back up safety measure. Is there a possibility it is causing the Oil Pressure Sending unit to go bad ? We thought maybe we were getting air bubbles into the unit ??
