Thread: 289 heater
Old 05-13-2014, 06:31 PM
Dan Case's Avatar
Dan Case Dan Case is offline
Original Shelby Owner
Originally Posted by Shelboss View Post
Thanks, I have the distance apart marked. What is the distance from the cockpit edge forward?
On an original car, everything is determined by where the windshield frame bolts on chassis substructure and the curve in the windshield frame. The bracket on the bottom center of the frame determines where inboard holes are for the deflectors, the outboard holes are just the same distance from the frame as the inboard ones going around the curve. To get a similar finished appearance you would have to mount a windshield and lay ancillaries out to match.
Dan Case
