Old 05-16-2014, 01:43 PM
jimbo01 jimbo01 is offline
Cobra Make, Engine: Backdraft #832
The Fast Fuel system was installed by Backdraft. It is a return system and has the correct fuel regulator installed. The system was installed according to Fast Fuel instructions. The problem is that the Aermotive fuel pump instructions states flat out that the system must gravity feed. Backdraft failed to properly install the line from the tank to the pump causing the pump to go bad. Thanks to Aeromotive it only cost $200.00 to replace it.
