Old 05-17-2014, 01:44 PM
Mr Jody Mr Jody is offline
Very true if no hidden kill switch. Two pieces of wire or one piece of wire and a screwdriver and I don't think it would even take 3 minutes to drive it away.
Pull the coil wire and put it in your pocket before you walk away.
And if you are concerned that the would-be theives would be smart enough to look for such things and to keep a spare on hand, you could even devise a fake coil wire to put in its place.
Of course as already mentioned, this would be only if no other means had been built in. A battery with a switch in a locked trunk to prevent it from even being turned over with hotwire attempts would be better. This would hopefully make any would-be thieves realize it's time to move on when nothing happens on the first attempt. Prevents any arcing and sparking damage, too.
If a man does not keep pace with his companions, perhaps it is because he hears a different rumble. Let him step to the sidepipes which he hears, however measured or far away. - H.D. Thoreau...if he had owned a Cobra
