Old 05-19-2014, 05:51 PM
madmaxx madmaxx is offline
Default 351W Clutch torque values
Appreciate any help. 351W dart block stroked to 427 with Tremec TKO 600. McCleod clutch and aluminum flywheel. Anybody know torque values for flywheel to crank, clutch plate to flywheel, bell housing to block? Should I put any lubricant on the pilot bearing? Appears I have a one piece rear main oil seal leak. If not the seal must be a plug as everything else is bone dry. Appears it started after I used synthetic.
