Thread: Gas odors
Old 05-20-2014, 10:59 AM
DanEC's Avatar
DanEC DanEC is offline
Lippy - good suggestion but it may be difficult to do on my car as I don't have sight glasses on my fuel bowls and with two carbs mounted backwards, my first-stage carb primary fuel bowl/screws are up against the rear carb. I can drain the rear primary and the front secondary w/o disturbing the carbs. Since the carbs are single inlet with a transfer tube, that might be enough to drain them to where they can't spill over. And then see if the stench lessens any.
I did decide to try the 1/4 inch spacers after reading your thread.
Thanks
