Old 04-08-2002, 06:59 AM
SeanTX SeanTX is offline
Default FFR Kit #1 for Sale
The first of the FFR kits is for sale: FFR 1011K.
Here are the mods:
Edelbrock Performer 5.0 heads
Edelbrock Performer 5.0 intake
70MM Throttle body and EGR
Vortech S Trim Supercharger
Ed Curtis custom ground cam
Kirban adjustable fuel pressure regulator
Flaming River quick ratio rack and pinion
Flaming River rag joint eliminator
Scorpion 1.72 Roller rockers
80mm Pro-M MAF meter
Classic Instruments gauges with reverse speedometer
Boost gauge
Fuel pressure gauge
Computer re-programming chip with serial interface and software
Steeda aluminum clutch quadrant
Steeda adjustable cable
Steeda firewall adjuster
36# fuel injectors
McLeod clutch
Aluminum Flywheel
130# valve springs
Gordon Levy built transmission (good for 600 lb/ft)
McLeod safety bellhousing
Pro 5.0 shifter
3.55 rear gear
MSD ignition
Accel coil
Nitto 275/50-15 Drag Radials
All leather interior
This car has been dyno'd at over 500 HP to the flywheel. I have both the cats and the j-pipes and the tonneau cover (not installed).
Asking $30,000 or best offer. Car is in Austin, TX. I'm negotiable.
I can email pics if you are interested.
