Thread: Fuel Additives
Old 05-22-2014, 09:49 AM
saturnkk's Avatar
saturnkk saturnkk is offline
This is the only somewhat related info I could find on Consumer Reports:
Problem: The mower won’t start. Old gasoline that oxidized over the winter is often to blame. Try removing it and adding fresh fuel. Always add a stabilizer to gas before fueling; certain additives might also help keep ethanol from harming internal parts.
Related
The Environmental Protection Agency has approved gasoline with 15 percent ethanol for use in cars year 2001 or newer, yet it prohibits its use in mowers and other power equipment, stating it may cause damage. A Department of Energy study found that E15 caused hotter operating temperatures, erratic running, and engine-part failure. But even gas with the usual 10 percent ethanol (E10) could help destroy small engines.
"Ethanol has inherent properties that can cause corrosion of metal parts, including carburetors, degradation of plastic and rubber components, harder starting, and reduced engine life," says Marv Klowak, global vice president of research and development for Briggs & Stratton, the largest manufacturer of small engines. "The higher the ethanol content, the more acute the effects." Servicing dealers are reporting similar problems, even with E10, according to the Outdoor Power Equipment Institute, the industry's trade group.
The OPEI also claims that proposed warnings at pumps are insufficient and that customers will blame equipment makers should mowers and other outdoor gear fail from being accidentally fueled with E15 gasoline. Using gasoline with more than the usual 10-percent ethanol has long voided most small-engine warranties but, until recently, the chance of doing so has been minimal.
Fuel additives such as Sta-Bil are now claimed to protect engines from ethanol by preventing it from settling out of the gasoline, attracting moisture, and concentrating its corrosive effects; we have not yet tested those additives. Here are other ways to protect your equipment:
