  #25 (permalink)
Old 05-25-2014, 04:54 PM
DanEC's Avatar
DanEC DanEC is offline
Jiffy Lube will not have an oil in stock that has a high enough ZDDP for solid lifters .
Patrick - Flat tappet hydraulic cams are just as much in need of high ZDDP oil as flat tappet solid lifter cams. There are variables - sometimes solid cams run higher spring pressure for more revs, but hydraulic cams don't have the acceleration ramps that solid cams have either.
