Old 05-28-2014, 10:02 PM
kal kal is offline
Cobra Make, Engine: Chev
Neutral
Default Under body exhaust
Hi, I will have under body exhaust but I will also put on the side pipes, unused and just for show. Made of 4" stainless and polished, looks absolutely fantastic. If you do this then it makes the car look more like the original. If you want to try the look get a piece of pipe, (pvc down down pipe will do) and hold it along the side of your car. Use your imagination and then make he decision. If you do go with the side pipes then have under body pipes finish before they come out the back of the car, this way you would not see them, it's abetter look.
