Old 04-08-2002, 05:32 PM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Your FMS catalog should have a speedo drive gear selection chart. Think the gear you want is the "Black" gear.
If you have a mechanical speedo, and you're still off, you can use a reduction gear device in your speedo cable to adjust. Will look up phone/website if you need one.
Newer speedos calibrate electronically.
