Old 05-30-2014, 02:18 AM
damage's Avatar
damage damage is offline
Cobra Make, Engine: Kirkham 427SC 482 Cammer
A bit hard to tell from the video but couldn't hear the fuel pump running in between start up attempts, I would put a fuel pressure gauge on it and make sure that fuel pressure is there both on ignition and during cranking.
I just had the same issue on mine and ended up putting a one way valve in my fuel line to keep pressure after the initial pump prime. If you don't maintain pressure the injectors won't get enough fuel through to start a cold engine.
Have you tried squirting fuel or aero start into it to see if it will fire that way.
