Old 06-01-2014, 08:11 PM
sambo's Avatar
sambo sambo is offline
Originally Posted by stephen low View Post
Paul I had the sparky install the standard interegation plug from the falcon so with the right gear I can simply plug into the system to check it out. Never having seen it done how do the scanners plug in and work?
The cheap $20 "ELM327" OBDII clones (see below) seem to work OK on the late model GM and VW engines in my cars.
ELM327 Obdii OBD2 Bluetooth Auto CAR Diagnostic Interface Scanner | eBay
You plug the adapter into your ODBII port and it talks via USB or bluetooth to the computer or mobile phone where you have installed the application.
If you have an Android phone grab the "Torque" app from the store (it's free) and you can borrow my bluetooth adapter. That should show you any generic fault codes but you may need to buy a more expensive hand held scanner to see manufacturer-specific codes.
If nothing else this will tell you whether your ECU is actually working. My car didn't start the first time due to voltage drop across the ignition barrel - not enough juice for the ECU. Fixed it with a new ignition barrel and dedicated relay just to be safe!
"A spectacularly fast car in a grand if dated tradition."
