Old 06-03-2014, 04:09 AM
Gaz64's Avatar
Gaz64 Gaz64 is offline
You have oil in your intake from leaking inlet valve seals, leaking inlet manifold or high blow-by.
The vacuum canister when it retards the timing pulls oil into the line and canister over time.
It may be only residue but builds up to the oil you see. How much are you seeing in the line?
Gary
