Old 04-09-2002, 06:33 AM
cobrajeff's Avatar
cobrajeff cobrajeff is offline
Default Webers will work with power brakes
I had Webers on the 351C in my Pantera. I made a vacuum "collector" log out of an old fuel log. I tapped all eight ports, and ran then to this collector - I had no problem with pulling enough vacuum for the power brakes on the Pantera (fairly mild BOSS 351 solid-lifter cam).
I have Webers on my ERA FIA Cobra on a 351C with an automatic. I have plumbed lines to two ports and added a vacuum can hidden under the car - this has been sufficient to gather enough vacuum to signal the tranny to shift.
My experience has been that air cleaners on Webers will dramatically affect tuning and power. Some people estimate the loss at 35-50 horsepower (probably not an issue with one of those "big" engines , but, for us "small-block" guys, that's a lotta ponies). If you plan to run air cleaners, I think the jetting and set-up of the carbs need to take that into consideration.
regards,
cobrajeff
CobraJeff
ERA P 202
