Thread: Clutch Oil Leak
Old 06-05-2014, 06:59 PM
mickmate's Avatar
mickmate mickmate is offline
I have seen the new style HTOB use all its stroke, bottom out the seal against the shoulder and chew the seal up. Check the master cylinder is appropriately sized if that is the case. I have had better luck with the early style you set with shims to the right position. I have even better luck with external clutch components. They are accessible and adjustable and you can see them working.
mickmate
http://www.actoncustom.com/
