Old 06-07-2014, 03:51 AM
DanEC's Avatar
DanEC DanEC is offline
Sooooooooo... are you gonna check your corner weights?
I would just for the heck of it but I have no idea where I would find a set of scales locally. Central Arkansas is not exactly Mecca for the roundy-round sports car crowd. If an opportunity arises I will do it. I suspect mine would come out reasonably close to your car.
My additional 15 lbs or so of sound dampening is probably slightly more situated towards the rear - say 5/10. I have steel heads and water pump - I would guess 40 - 45 lbs that would fall more on the front. No roll bar takes about 20 lbs off the rear axle. My tail pipes probably add about 20 lbs to the rear. The jag suspension adds about 45 lbs to the rear. My full street bumpers add about 10 lbs front and rear each (not much to them). That works out about +50 lbs on front and +55 lbs on the rear.
