Old 06-08-2014, 01:01 PM
Keithc8 Keithc8 is offline
Default New 496C.I. Cammer build
Finally got all the parts together to start a 496C.I. Cammer FE build. Pond 4.310 bore with a 4340 4.250 stroke steel crankshaft. Premium pump gas friendly but customer plans on switching over to natural gas later. Coon KC CNC ported heads with Ferrrea hallow stem valves coated with Titankote C14 coating for durability and to hold up to the heat of the natural gas with Pac Bee Hive valve springs. Dailey Engineering dry sump oil pump and oil pan. We will use a Hilborn electronic stack injection set up with the Fast ECU and wiring harness. We will fully port the intake as needed matching to the heads and stack units. Making the opening at the stack bigger than the stacks has shown to help reversion and idle quality plus help HP.
This will be a unique build to say the least and we will dyno on gas and the customer will have it chassi dynode and tuned when he goes to the natural gas. That will be interesting for sure. We will follow up with some pictures and more information as this comes together. This should come together in the next month or so.
Thanks, Keith Craft
Keith C
