Old 06-17-2014, 03:16 PM
Tommy's Avatar
Tommy Tommy is offline
Jurgen,
I looked at one of your earlier posts and note that these are new tires. Did you have the same problem with the previous tires? If so, it's not likely the tires that need attention. If the problem arose with the new tires, I suspect you have a bad tire and no amount of balancing will solve it. .... I've not yet heard a theory about the operation of the balancing beads that explains why they would go to the side of the tire that most needs the additional weight of the beads. I suspect they work on the placebo effect.
BTW, do you have a friend with a SPF who would let you swap wheels for a few miles?
Tommy
Previously owned EM Cobra
