Old 06-18-2014, 02:21 AM
ha_pe_1968 ha_pe_1968 is offline
Cobra Make, Engine: SPF 2234 Diamond Edition, Roush 427R
Hi!
Had the same problems at my Superformance and decided to try it from cheap to more expensive - thought it was the fluid because the problems started only when the engine was hot.
1. check the clutch adjustment and change to a high boiling brake fluid like ATF super blue or Willwood or castrol SRF, bleed very carefully..when you are not sure..bleed once again (sleeve and master cylinder)
...if problem is not solved
2. Replacing Rubber Clutch lines with teflon ones and add heat shields to the lines where they are near to the headers
....if not solved...
3. pull the tranny and check your clutch
Of course in my case it was No. 3 ...a totally worn clutch...but had no slippery so i did not expected it.
Greetings from overseas
Peter
