Old 06-18-2014, 06:43 AM
kevins2's Avatar
kevins2 kevins2 is offline
Cobra Make, Engine: ERA #795 427 S/C completed Jan. '14 - '68 FE 427 side oiler
Hi Dan,
The play you describe is normal. You may recall I posted a video on my thread of a bearing problem I had with the Jag rear. With someone moving the wheel at the 12 and 6 position, you could clearly see the inboard brake rotor wobble, indicating it was a defective bearing on the inside where the half shaft mounts to the diff, so that would be what you want to look at when looking under the car with someone moving the wheel. ERA replaced the bearing and that solved the problem.
Kevin
"Anyone who drives faster than you is a maniac and anyone who drives slower than you is an idiot" - George Carlin
