Old 06-18-2014, 05:58 AM
Dan Case's Avatar
Dan Case Dan Case is offline
Original Shelby Owner
Hey Larry I think that the 3 is a protrusion not an indentation. I was thinking of sand casting a few. I have an idea on putting the number in there.
The numeral three is raised above the surface about 0.01 inch. (hard to measure)
Brass moves pretty easily. I was wondering about trying making a steel die with a recessed numeral. Make the die fit the shape of a wing. Buy some common ones with small numerals, polish off the small numerals, and either press or forge the wing in the die to press a raised numeral in. Finally deal with any extra marks the operation created before a nice chrome plating job. If that didn’t work maybe coat the wing center with some medium soft solder (tin-antimony maybe) and press a number in the solder coat before plating?????????
Dan Case
