Old 06-18-2014, 05:40 PM
DanEC's Avatar
DanEC DanEC is offline
Originally Posted by kevins2 View Post
Hi Dan,
The play you describe is normal. You may recall I posted a video on my thread of a bearing problem I had with the Jag rear. With someone moving the wheel at the 12 and 6 position, you could clearly see the inboard brake rotor wobble, indicating it was a defective bearing on the inside where the half shaft mounts to the diff, so that would be what you want to look at when looking under the car with someone moving the wheel. ERA replaced the bearing and that solved the problem.
Kevin
Kevin - I remember your bearing issue but I can't seem to find the thread where you posted the video. Was it in your build thread?
Thanks
