  #24 (permalink)
Old 06-19-2014, 08:40 AM
scottj scottj is offline
Cobra Make, Engine: Everett-Morrison, 434 cid
Originally Posted by xlr8tr View Post
does an EFI setup (stack or throttle body) lessen the bucking at low RPM at all if you are using a big cam?
Yes... my latest engine is injected (throttle body). It makes peak hp @ 7400 rpm and cruises in any gear (6spd) @ 1400 rpm without bucking. My other engines were built for track use. This time around I built for street use and low maintenance, without giving up any performance. Same cid, injected, bigger heads, and a hydraulic roller made more HP at 200 rpm higher. We gave up over-rev because of the hydraulic cam, but I don't need over-rev on the street anyway.
Note: 27 different combinations were dyno tested during development.
