Old 06-19-2014, 05:14 PM
blykins blykins is offline
Doesn't take much....hit the 3 center bulkheads with a die grinder...
Did a lot of checking...
Checked piston/cylinder clearance. Checked deck height on four corners.
Also did a little oil pump feed hole gasket matching...
Broke all the rods down from where I had checked rod bearing clearances, and I'm dropping the rotating assembly off tomorrow to be balanced.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
