Old 06-22-2014, 08:36 PM
leroy17's Avatar
leroy17 leroy17 is offline
Thanks guys and I appreciate the feedback and comments.
This was built by Paul (Ledge - past forum member) from Finch Restorations. Its not hard to search this forum to follow the build histroy and topics relating to this vehicle and view Pauls gallery for many build photos right from when it was at the factory in the frame jig.
Paul had the motor rebuilt due to the donor motor experiencing a failure. Current motor is strong, healthy, well cared for and low k's.
Dean is correct in that we have talked at lengths.
I have provided Dean the original owner/builder (Paul) details, in addition to the engine builders details who are a prominent engine builder in SA and I have also obtained a contact at SA rego (name and number) who also knows the previous owner and the car. In addition I have advised what these conversations contained (as advised by SA rego) and items to assist in what is required to satisfy re-rego in SA. I have confirmed that sensors not required with the curret set up were terminated seperatly in the loom in the engine bay (easily accessable) and that original wiring from point of termination (4 or 6 wires for memory) on these conectors are included. Confirmation also provided that this is not run by an aftermarket ECU.
There has also been 40 high res unaltered and unedited current photos provided to assist in vehicle condition assessment.
This information is what I will share with any potential buyer as a responsible, honest and reliable seller.
Perhaps I should also mention that I have all engineering reports, tests and approvals including photographs for seat and chassis testing, lane change test, tortion test, vehicle specifications and engine manual and wiring diagram. All recepits for purchased items and work completed.
There is also sufficient paint provided in a sealed container to fully paint the car again in the same custom colour should the new owner desire or to keep this for any repair work if needed. For memory this is a PPG mix, quality and expensive.
I trust that this gives an insight on what is available to any interested party.
Cheers.
