Thread: Fuel pumps.
Old 06-23-2014, 03:01 AM
Default What kind of fuel system is on the motor???
Little help here? Carb of FI? Fi system I run with a power adder was 2, 255liter walbro pumps in the tank on seperate lines to the injectors. Couple of guys are running weldon fuel pumps. Need to have this pump low as possible for pickup. Hope you have a couple of baffles in fuel tank. If running foam also, need to keep eye on it for breaking down with Methol in gas or race gas. Fuel lines are 1/2" and 3/8" return. If you are running a high power motor, this would be the correct sizes. If running a small stock motor 3/8" and 5/16" return. This is for either FI or carb. Rap and clamp lines about every 12" to stop any vibrations. Rick L. Ps try and keep away from the heated areas and rap the fuel lines also.
