Thread: Fuel pumps.
Old 06-23-2014, 07:16 AM
Cobra #3170 Cobra #3170 is offline
Default Fuel System
Originally Posted by Dimis View Post
Thx Rick.
Say a 650/650 deal fe.
Dual quad with -6an from tank to Holley and the -8an to the edelbrock pump at the engine with -8an to carbs.
The -6 is probably going to be swapped out for -10an and the -8an used for a return line.
The Holley at the tank and the edelbrock at the engine won't keep up.
I guess what I'm looking for is how others have gone about it to see what is best practice and piggy back off that.
Thx
I could never understand why everybody runs such huge lines unless they are serious drag racers or running methanol. I have 3/8 feed and return lines
feeding 65 lb/hr injectors and have never had a starvation problem. I use a Holley Blue to feed my surge tank and a Bosch high pressure pump to feed the injectors. If you look at the brake specific requirements for your engine you will see that the gallons per hour will be well below what a 3/8 line can supply, by the way my engine builder agrees.
Engine is 850/632 chipped at 8000. Maybe it is a big hat/ no cattle deal?
