Old 06-24-2014, 07:32 AM
vector1 vector1 is offline
Cobra Make, Engine: jbl
Originally Posted by bobcowan View Post
After you find the area that's loose, Drill a small hole through the pipe and the loose baffle. Drill the hole in the pipe slightly larger. Then pin down the baffle with a sheet metal screw.
This is what I was going to suggest or something similar, run a stainless sheet metal screw up from the bottom to hold things still. Probably cut the tip off so there is a blunt end then try to bottom it on the baffle.
