Originally Posted by vector1
This is what I was going to suggest or something similar, run a stainless sheet metal screw up from the bottom to hold things still. Probably cut the tip off so there is a blunt end then try to bottom it on the baffle.
I'm on my second set of Shelly Valley sidepipes for this reason. I've tried this solution a few times on each set with varying results. From experience and discussion with Dana at Shell Valley, the "sweet spot" is to drill and run the screw about 1.5" back from the weld.
The other, and only permanent option is to retro-fit the sidepipes with Classic Chambered inserts.
http://www.classicchambered.com/classic/cobra.html
This is my plan. I'm done with this "whack a mole" game!
