Old 06-26-2014, 04:12 PM
DanEC's Avatar
DanEC DanEC is offline
Default How much air cleaner to hood clearance is enough?
I installed K&E filters (thank you Yugo) in my S&H air cleaners on my FE dual quad set up and measured my clearances with modeling clay. I have a bit over 3/8 inch clearance from the top of the acorn nut to the hood underside on the rear air cleaner. I can change out the acorn nuts for common nuts if I have to.
I think 3/8 inch should be safe - I also have my driver side motor mount through bolted. Haven't started the motor yet. Anyone have issues with underside hood contact with around 3/8 inch nomimal clearance??
Thanks
